TwinTurbo.NET: Nissan 300ZX forum - Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Subject Re: Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors
Posted by MaxxAction on September 20, 2012 at 5:47 PM
  This message has been viewed 262 times.
In Reply To Re: MAF, PTU, CAS, Plugs, plug gap, boost leak, injectors posted by Fatal on September 20, 2012 at 07:07 AM
Message Buy an inner tube....
Cut two 5x5 inch squares out of it. Pull the maf or mars, clamp the rubber over the breather openings. Use an air gun and a piece of hose on one of the nipples on the balance tube to put the air in, listen for leaks. You can turn your key on and use your boost gauge to check the pressure.
